お世話になっております。赤坂と申します。
新品のArmadillo640を起動して、構築済みのArmadillo640のイメージファイルをddコマンドでコピーしたところ、
(dd if=/media/backupARM****.img of=/dev/mmcblk0 bs=1M)
以下のメッセージで終了してしまいました。
[ 337.659833] systemd: 24 output lines suppressed due to ratelimiting
[ 337.666503] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 337.666503]
[ 337.676081] CPU: 0 PID: 1 Comm: systemd Not tainted 4.14-at12 #1
[ 337.682377] Hardware name: Freescale i.MX6 Ultralite (Device Tree)
[ 337.688894] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 337.697023] [] (show_stack) from [] (panic+0xc8/0x238)
[ 337.704244] [] (panic) from [] (do_exit+0x9d4/0x9f0)
[ 337.711274] [] (do_exit) from [] (do_group_exit+0x40/0xa4)
[ 337.718853] [] (do_group_exit) from [] (get_signal+0xfc/0x660)
[ 337.726791] [] (get_signal) from [] (do_signal+0xc4/0x468)
[ 337.734369] [] (do_signal) from [] (do_work_pending+0xa8/0xc0)
[ 337.742307] [] (do_work_pending) from [] (slow_work_pending+0xc/0x20)
[ 337.750877] ---[ end Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 337.750877]
その後再起動しても以下のメッセージで起動が止まってしまいコマンドも実行できない状況です。
どの様にして復旧できますでしょうか?
[ 1.420805] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 1.436382] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.444562] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.453344] Freeing unused kernel memory: 1024K
[ 1.462233] Starting init: /sbin/init exists but couldn't execute it (error -20)
[ 1.473029] Starting init: /etc/init exists but couldn't execute it (error -13)
[ 1.482265] Starting init: /bin/sh exists but couldn't execute it (error -8)
[ 1.489421] Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[ 1.503605] CPU: 0 PID: 1 Comm: swapper Not tainted 4.14-at3 #8
[ 1.509531] Hardware name: Freescale i.MX6 Ultralite (Device Tree)
[ 1.515760] [] (unwind_backtrace) from [] (show_stack+0x10/0x14)
[ 1.523530] [] (show_stack) from [] (panic+0xc8/0x238)
[ 1.530428] [] (panic) from [] (kernel_init+0xfc/0x10c)
[ 1.537411] [] (kernel_init) from [] (ret_from_fork+0x14/0x2c)
[ 1.544998] ---[ end Kernel panic - not syncing: No working init found. Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
佐藤です。
インストールディスクを作成し、それを使用することで復旧できるかと思います。
https://manual.atmark-techno.com/armadillo-640/armadillo-640_product_manual_ja-1.12.0/ch11.html#sct.use_install_disk
> 佐藤です。
回答有難うございます。
「11.1. インストールディスクを使用する」の手順でインストールディスクを作成しようとしたのですが
Oracle VM VirtualBoxでSDカードがマウントできない(やり方が分からない)のでUSBメモリに
.imgを作成して、そのファイルをSDカードにコピーしようとしてます。
「4.SDカードにインストールディスクイメージを書き込みます。 」で
sudo dd if=install-disk-sd-a640-[version].img of=/dev/sdb bs=4M conv=fsync
とあるのですが、[version]名はどの様に確認できますか?
コマンドを実行すると、
dd: 'install-disk-sd-a640-[version].img' を開けませんでした: そのようなファイルやディレクトリはありません
となってしまいます。
申し訳ありませんがよろしくお願いします。
<追加質問>
・既に構築済みのArmadilloからはインストールディスクは作成できないのでしょうか。
取説の通りATDEからでないと作成できないのでしょうか。
佐藤です。
> 回答有難うございます。
> コマンドを実行すると、
> となってしまいます。
以下からダウンロードできます。
https://users.atmark-techno.com/files/downloads/armadillo-640/image/install-disk-sd-a640-20191030.img
windows上でも、"Win32 Disk Imager"等のイメージ書き込みツールを使用すると、SDカードに書き込めます。
こちらで復旧できるかお試しください。
> <追加質問>
構築済みのArmadilloのクローンを作りたいということであれば以下の投稿が参考になるかと思います。
https://users.atmark-techno.com/node/3340
> 以下からダウンロードできます。
> こちらで復旧できるかお試しください。
> > <追加質問>
上記からダウンロードしたimgファイルを「Win32 Disk Imager」でSDカードへ書き込み、
ArmadilloをSDブートして復旧することができました。
ひとまず助かりました。
目的のクローン作成については、上記投稿を参考にやってみます。
有難うございました。
