tsato
2023年8月21日 13時16分
Armadillo-X1(メモリ512MB)でOSがdebian9のシステムですが、
こちらにPython3をインストールして、続けてnumpyやpandasモジュールをpip3にてインストールしようとしたところ、エラーが発生してインストール出来ませんでした。(過去には出来ていたような気がしたのですが・・・)
以下、numpyをインストールのエラー表示です。(初回と2回目以降で若干違ってますが2回目以降の方です)
root@armadillo:~# sudo pip3 install numpy Collecting numpy Using cached https://files.pythonhosted.org/packages/01/1b/d3ddcabd5817be02df0e6ee20d64f77ff6d0d97f83b77f65e98c8a651981/numpy-1.18.5.zip Building wheels for collected packages: numpy Running setup.py bdist_wheel for numpy ... error Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-i4qtitqi/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" bdist_wheel -d /tmp/tmphxb076rrpip-wheel- --python-tag cp35: Running from numpy source directory. Cythonizing sources warning: _generator.pyx:3330:8: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 warning: /tmp/pip-build-i4qtitqi/numpy/numpy/__init__.pxd:17:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 warning: /tmp/pip-build-i4qtitqi/numpy/numpy/__init__.pxd:17:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 warning: /tmp/pip-build-i4qtitqi/numpy/numpy/__init__.pxd:17:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 warning: _philox.pyx:19:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 warning: /tmp/pip-build-i4qtitqi/numpy/numpy/__init__.pxd:17:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 Error compiling Cython file: ------------------------------------------------------------ ... self.rng_state.ctr.v[i] = counter[i] self._reset_state_variables() self._bitgen.state = <void *>&self.rng_state self._bitgen.next_uint64 = &philox_uint64 ^ ------------------------------------------------------------ _philox.pyx:195:35: Cannot assign type 'uint64_t (*)(void *) except? -1 nogil' to 'uint64_t (*)(void *) noexcept nogil' Processing numpy/random/_bounded_integers.pxd.in Processing numpy/random/_generator.pyx Processing numpy/random/_common.pyx Processing numpy/random/mtrand.pyx Processing numpy/random/_philox.pyx Traceback (most recent call last): File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 238, in <module> main() File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 234, in main find_process_files(root_dir) File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 225, in find_process_files process(root_dir, fromfile, tofile, function, hash_db) File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 191, in process processor_function(fromfile, tofile) File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 81, in process_pyx [sys.executable, '-m', 'cython'] + flags + ["-o", tofile, fromfile]) File "/usr/lib/python3.5/subprocess.py", line 271, in check_call raise CalledProcessError(retcode, cmd) subprocess.CalledProcessError: Command '['/usr/bin/python3', '-m', 'cython', '-3', '--fast-fail', '-o', '_philox.c', '_philox.pyx']' returned non-zero exit status 1 Traceback (most recent call last): File "<string>", line 1, in <module> File "/tmp/pip-build-i4qtitqi/numpy/setup.py", line 488, in <module> setup_package() File "/tmp/pip-build-i4qtitqi/numpy/setup.py", line 469, in setup_package generate_cython() File "/tmp/pip-build-i4qtitqi/numpy/setup.py", line 275, in generate_cython raise RuntimeError("Running cythonize failed!") RuntimeError: Running cythonize failed! ---------------------------------------- Failed building wheel for numpy Running setup.py clean for numpy Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-i4qtitqi/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" clean --all: Running from numpy source directory. `setup.py clean` is not supported, use one of the following instead: - `git clean -xdf` (cleans all files) - `git clean -Xdf` (cleans all versioned files, doesn't touch files that aren't checked into the git repo) Add `--force` to your command to use it anyway if you must (unsupported). ---------------------------------------- Failed cleaning build dir for numpy Failed to build numpy Installing collected packages: numpy Running setup.py install for numpy ... error Complete output from command /usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-i4qtitqi/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-h6udytpy-record/install-record.txt --single-version-externally-managed --compile: Running from numpy source directory. Note: if you need reliable uninstall behavior, then install with pip instead of using `setup.py install`: - `pip install .` (from a git repo or downloaded source release) - `pip install numpy` (last NumPy release on PyPi) Cythonizing sources warning: _philox.pyx:19:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 warning: /tmp/pip-build-i4qtitqi/numpy/numpy/__init__.pxd:17:0: The 'DEF' statement is deprecated and will be removed in a future Cython version. Consider using global variables, constants, and in-place literals instead. See https://github.com/cython/cython/issues/4310 Error compiling Cython file: ------------------------------------------------------------ ... self.rng_state.ctr.v[i] = counter[i] self._reset_state_variables() self._bitgen.state = <void *>&self.rng_state self._bitgen.next_uint64 = &philox_uint64 ^ ------------------------------------------------------------ _philox.pyx:195:35: Cannot assign type 'uint64_t (*)(void *) except? -1 nogil' to 'uint64_t (*)(void *) noexcept nogil' numpy/random/_bounded_integers.pxd.in has not changed numpy/random/_generator.pyx has not changed numpy/random/_common.pyx has not changed numpy/random/mtrand.pyx has not changed Processing numpy/random/_philox.pyx Traceback (most recent call last): File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 238, in <module> main() File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 234, in main find_process_files(root_dir) File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 225, in find_process_files process(root_dir, fromfile, tofile, function, hash_db) File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 191, in process processor_function(fromfile, tofile) File "/tmp/pip-build-i4qtitqi/numpy/tools/cythonize.py", line 81, in process_pyx [sys.executable, '-m', 'cython'] + flags + ["-o", tofile, fromfile]) File "/usr/lib/python3.5/subprocess.py", line 271, in check_call raise CalledProcessError(retcode, cmd) subprocess.CalledProcessError: Command '['/usr/bin/python3', '-m', 'cython', '-3', '--fast-fail', '-o', '_philox.c', '_philox.pyx']' returned non-zero exit status 1 Traceback (most recent call last): File "<string>", line 1, in <module> File "/tmp/pip-build-i4qtitqi/numpy/setup.py", line 488, in <module> setup_package() File "/tmp/pip-build-i4qtitqi/numpy/setup.py", line 469, in setup_package generate_cython() File "/tmp/pip-build-i4qtitqi/numpy/setup.py", line 275, in generate_cython raise RuntimeError("Running cythonize failed!") RuntimeError: Running cythonize failed! ---------------------------------------- Command "/usr/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-i4qtitqi/numpy/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-h6udytpy-record/install-record.txt --single-version-externally-managed --compile" failed with error code 1 in /tmp/pip-build-i4qtitqi/numpy/
debian10のファイルシステムアーカイブの端末でも駄目でした。
他のLinuxディストリビューションでは試せてないですが、Windowsでは問題なく出来ました。
何か原因は分かりますでしょうか。
因みにエラー内容からCython関係かと思いCython(3.0.0)は問題なくインストールできましたがやはりnumpyは駄目でした。
tsato
2023年8月21日 16時42分
ご回答ありがとうございます。
こちらでも調べていて原因が見えてきました。
まずdebian10では、ご教授のとおりpip3を使わず"apt-get install python3-numpy"の指令にてモジュールがインストールできました。
debian9ではやはりインストールできませんでした。調べると、公式debianリポジトリから"stretch"ディレクトリが削除されてたためでした。
(debian9のLTSサポートが今年6月に終了していたため)
とりあえずリポジトリリストの/etc/apt/sources.listの参照先ディレクトリ名をstretch→oldoldstable(debian10のものですが)に変更したら、updateが出来、pythonモジュールも形上はインストールできました。(まだ動作確認は出来ていません)
根本原因として、debian9がLTSサポート終了している以上は継続開発の基盤としてはdebian10への移行を検討した方が良い、ということになりました。
ありがとうございました。
at_ohsawa
2023年8月21日 17時05分
現在のoldoldstableの実体はbuster(debian 10)なので、もしstretch(debian 9)の状態から
source.listだけ書き換えると、他のライブラリとの依存関係が壊れるので
OSの完全なアップグレードが必要です。完全にアップデートするのであればapt-get dist-upgradeする必要があります。
ただ、armadilloで実行すると遅いので、運用中中でなければ、最初からdebian10 busterのユーザーランドアーカイブを
配っているので、そっちを使ったほうが速いです。
https://armadillo.atmark-techno.com/resources/software/armadillo-x1/use…
ユーザーランドだけ入れ替えるのが面倒であれば、いっそ全て消してしまうインストールディスクもあります。
https://armadillo.atmark-techno.com/resources/software/armadillo-x1/dis…
dist-upgradeで完全にアップデートしないまま、numpyをインストールすると、numpyが内部で
Cモジュールを使っているため、それがdebian9とdebian10とではlibc等周囲のライブラリのバージョン
と不整合となり実行時にエラーします。
このあたり、完全に把握していないのであれば、↑のインストールディスクでのクリーンインストールをオススメします。
ちなみに、余談ですが最初のビルドエラーについてはCythonが新しすぎるせいですね。
この時代のpythonに合わせてpipで入るnumpyのバージョンも調整されて古いものが
来ますが、numpyのwheelが要求するCythonのバージョンが不定(versionを特定しない)
ので最新の3.0.0を使おうとします。が、3.0.0だと、この時代のnumpyバージョンに対しては
エラーチェックが厳しすぎてビルドに失敗するため、敢えて古いCythonを入れてpipを使わずに
ビルドするとビルドが成功します。
が、そんな面倒なことはせずにaptでインストールすると良いと思います。
at_ohsawa
2023年8月21日 16時25分
> お世話になります。
過去のインストールはapt-get install python3-numpyでインストールしていませんでしたか?
これなら特に問題なくインストールできます。また、新規で開発するのであれば、debian 10にしたほうが良いです。
